Duda Parasol
zantos
420i-GC/iX2-x30
9 Feb 2017
Una preguntilla... Los que tenéis parasol en el F30, ¿de qué medidas tiene que ser? Estoy en búsqueda de uno, que ya empieza a hacer falta...
F32 435i MSport
5 Nov 2014
Mejor pregunta en el concesionario o en alguna tienda que equipe películas para los cristales por el cerámico Air Blue, de Llumar que bloquea la radiación ultravioleta. Funciona igual que el acristalamiento con protección solar, si no lo equipaste de fábrica. No es compatible con head up display.
Por qué no le das un vistazo a este hilo:
https://www.bmwfaq.org/threads/seri...nto-de-proteccion-solar.905107/#post-15906555
"LLumar Air Blue 80 provides extremely effective protection against ultraviolet rays and infrared heat that can penetrate ordinary window glass.
Ultimate UV Ray Protection
Even if your side windows are tinted, you’re still missing an important level of protection from the sun: the front windshield. LLumar Air Blue 80 is a non-metalized, non-conductive ceramic technology film with 43% heat rejection, maximum ultra-violet rejection, excellent optical clarity, and scratch- and corrosion-resistant properties.
This film has a 78% Visible Light Transmittance, and its optical clarity and low reflectivity will not interfere with night driving. Air Blue 80 will also block 99% of the sun’s UVA and UVB rays and is recommended by the Skin Cancer Foundation. This film also has signal-enabling properties to ensure no signal interference with wireless devices.
With fuel costs on the rise, every opportunity for savings is crucial. By reducing the interior temperature of your car, LLumar Air Blue 80 films can reduce the need to run your vehicle’s cooling system, and that helps your car burn less fuel.
Since tinting windshields is illegal in most states, LLumar Air Blue 80 is perfect for your windshield! It is virtually clear and will still provide excellent heat reduction. If you don’t like the appearance and darkness of tint, we can also apply LLumar Air Blue 80 to your whole vehicle! We’ve installed LLumar Air Blue 80 on cars, trucks, vans, and SUVs. We also offer sunstrips for your windshield.
Recommended by The Skin Cancer Foundation
Llumar window film products are backed by the Skin Cancer Foundation’s Seal of Recommendation. The Skin Cancer Foundation’s Seal of Recommendation is granted to sun protection products that have been reviewed by and meet the specific criteria of an independent Photobiology Committee. At Absolute Perfection, we only use the highest quality products.
The Seal of Recommendation is a symbol of safe and effective sun protection that is recognized by consumers worldwide. Fight the battle against skin cancer and get your windows tinted today!"
http://www.aptinting.com/llumar-air-blue-80/
zantos
420i-GC/iX2-x30
9 Feb 2017
@felix55, muy graciosillo... JEJEJE. Me refiero a que como hay de 60, 70 u 80 cm. de altura, qué teníais vosotros... ya veo que en el tuyo eso no influye... @Mauricio Palacios. MD, no es plan de re-equipar eso, es sólo para cuando el coche esté aparcado en la calle...
grmsmp
BMW F30
30 Nov 2016
Buenos días. Yo también estoy pensando en poner parasoles en ventanillas traseras y luna trasera. No pienso en tintar los cristales ya que mi F30 es negro con tapicería Beis y perdería el encanto. ¿Alguien sabe precios de las cortinillas originales de BMW?, me refiero a las que se quedan fijas, no las enrollables de serie. ¿ Alguien ha comprado algunas cortinillas solares a medida de alguna pagina? Si alguien sabe algo sobre este tema le agradezco que me informe. Ahora con el verano y los niños pequeños me veo en la obligación de ponerlas.
Muchas gracias a todos.
bert
328iF30/116iF20
17 Oct 2007
Hola.
Yo llevo la de la luna trasera una no original de un lote que compre. Tengo las laterales para para vender, pues el mio las laterales las llevaba de origen. Si quieres ver como queda la trasera o te interesan las laterales escribeme.
felix55
F31 MA
18 Ene 2004
Yo tengo el mismo, pero para meterlo en la bolsa,tela.....
si a veces parece que estes estrangulando a alguien en el coche :descojon:
Yo en verano ni me molesto en meterlo lo dejo doblado entre el asiento del copiloto y la consola central.
amenhotep
F31 318DA M
14 Mar 2016
Sin medirlo, creo q debe ser el de 70. Al Mondeo tuve q comprar uno mas grande y ahora uso el que me dejaron para el Ford, al comprarlo, con la publicidad hacía dentro
zantos
420i-GC/iX2-x30
9 Feb 2017
Sí, para el F30 le viene bien de 70, para el F48 compré uno de 70 que se le gustó a la jefa pero quedaría mejor de 80, aunque con 70 va bien.
jaferca
320d f30
21 Nov 2006
Hola.
donde comprastes la trasera ? se va acercar el verano y quisiera tenerla para entonces
bert
328iF30/116iF20
17 Oct 2007
Lo compre de segundamano y era un lote con las de puertas traseras laterales y luna trasera. La de la luna trasera que es la que he montado esta partida en dos, no es entera como la original, pero la verdad, a mi no me disgusta en absoluto, hace su papel y queda muy bien.
Y las de las puertas traseras la tengo que poner en venta, pues mi coche las traia de origen. Lastima que no necesites estas.
