Product Catalogue 2004 - page 60
Os pongo un extracto sacado de la página de QUAIFE con los precios actualizados. Están en libras. Una libra cotiza en la actualidad entorno alos 1.45 euros, o dicho de otra manera a 240 pesetas.
QUAIFE ATB DIFFERENTIALS
The QUAIFE ATB differential is designed to prevent the complete loss of drive that occurs with a conventional differential when one wheel slips. Whilst requiring some torque in the slipping wheel, the QUAIFE unit is progressive in action but never locks – controlled power is transmitted to all the driving wheels. Ideally suited to high powered front wheel drive systems, QUAIFE ATB differentials are also used in rear and four wheel drive vehicles where optimum traction is required.
Installation is identical to the normal differential with bearing pre-loads and pinion mesh being restored to the original manufacturers’ settings. Servicing of the unit is simple as all gear pinions are free fitting and normal final drive lubrication oils are retained. Due to the internal design of the QUAIFE ATB differential, all driving wheels must be elevated when servicing brakes, wheels etc.
Alfa Romeo 156 V6 QDH6E1 £POA
Alfa Romeo 164 / 155 QDH2E1 £POA
Audi (Front), Coupe GT, 4000 Quattro, Quattro Coupe (016/093 trans) QDF4QA £685.00
Audi (Front), A4 2WD (pre-1999, 012 transmission) QDF6QA £750.00
Audi (Rear), A4 Quattro QDF4QA £685.00
Audi A3 1.8/1.8T/Tdi (02J transmission) QDF10RA £525.00
Austin Healey 3000 QDF13KH £POA
Austin Healey Sprite QDF5K2 £460.00
Birkin QDH1L1 £494.00
BMW 2002, 318i, 320i QDF4N1 £585.00
BMW Z3 4 cyl, 318ti (E36 compact) QDF6N1 £585.00
BMW 325i (E30,E36), 525-535I (E28,E34), 633-635csi, 735i QDF2N2 £660.00
BMW M3 4 cyl (E30), M3 6 cyl (E36), Z3 6 cylinder QDF2N2 £660.00
BMW 325e (E30), 528e (E28), 328i (E36) QDF3N1 £660.00
BMW M5, M6, V12 QDF5N1 £660.00
BMW 540i (E39) QDF8N1 £660.00
Caterham (De’Dion axle) QDF15ZCAT £495.00
Caterham (English axle) QDF5ZCAT £395.00
Caterham (Ital/Marina axle) QDF8KCAT £460.00
Citroen ZX (BE3 gearbox) QDF3HC £490.00
Citroën AX (MA gearbox) QDF9H1 £460.00
Daimler Chrysler
Chrysler Sebring, Cirrus QDF3IC £POA
Dodge Neon auto, Avenger, Stratus QDF3ID £POA
Dodge Neon SRT-4 QDH1U2 £POA
Dodge Shelby FWD (555/568 transmission) QD16B1 £POA
Dodge Viper V10 QDF9S1V £POA
Ford 9" - live axle QDFH1R £POA
Ford Atlas (Capri or ZF spline) QDF6Z4 £525.00
Ford Atlas ZF spline (Pad type) QDF6Z4P £750.00
Ford Cortina MK3,4 & 5 QDF23Z1 £POA
Ford English QDF5Z11 £395.00
Ford Escort/Sierra 6 1 / 2 " 4X4 heavy duty front differential case E18Z102 £640.00
Ford Escort/Sierra 6 1 / 2 " 4X4 front QDF16Z £495.00
Ford Escort Cosworth rear (including flanges) QDF15ZFL £685.00
Ford 'BC' Type 1B5 - Escort / Fiesta / Focus / Ka / Puma QDF7Z5 £475.00
Ford Explorer (4x4) Front QDF37Z £POA
Ford Focus SVT (6-speed Getrag) QDF38Z1 £495.00
Ford MT75 centre (runs with QUAIFE dog engagement gearkit only) QDF17Z £875.00
Ford MTX 75 / Contour (USA) / Focus / Mondeo / RS2000 QDF20Z2 £475.00
Ford Mustang 8.8" QDF29Z1 £POA
>> page 61>>
back to
