Buenas
La segunda referencia debe ser exclusiva del mercado americano y no se suministra para el resto de mercados
Please initial and route to the following for information before filing
[FONT=Arial,Bold]X
[/FONT]Service Manager [FONT=Arial,Bold]X [/FONT]Warranty [FONT=Arial,Bold]X [/FONT]Service Technicians - Initial Below
[FONT=Arial,Bold]X
[/FONT]Service Advisor Parts Mgr.
[FONT=Arial,Bold]X
[/FONT]Service Advisor Body Shop
[FONT=Arial,Bold]X
[/FONT]Shop Foreman PDI Dept.
[FONT=Arial,Bold]FIX IT RIGHT THE FIRST TIME, ON TIME, EVERY TIME [/FONT]�� ��
2003 BMW of North America, LLC by: KRS
[FONT=BMWTypeLight,Bold]Installation Instructions
[/FONT][FONT=BMWTypeLight,Bold]Page 1 of
June 2003
Phone, Navigation Systems B84 03 03 Product
Development
[/FONT][FONT=BMWTypeLight,Bold]SUBJECT
[/FONT][FONT=BMWTypeLight,Bold]BMW Universal Bluetooth
[/FONT][FONT=BMWTypeLight,Bold]TM [/FONT][FONT=BMWTypeLight,Bold]Hands-Free-Kit
[/FONT][FONT=BMWTypeLight,Bold]MODEL
[/FONT]
E46 - Sedan/Sport Wagon as of 3/02
"Never use any electronic device or make any inputs while driving that may distract you from driving
safely.
Pay attention to traffic laws and road conditions\situations. Safe vehicle operation is the driver's
responsibility. Always wear your safety belt."
[FONT=BMWTypeLight,Bold]INSTALLATION TIME
[/FONT]
The installation time for this kit is approximately 1.25 hour
These instructions were developed especially for BMW vehicles and are not to be compared to any
existing instructions for vehicles other than BMW. No methods other than those specified in this
document are to be used to install the
[FONT=BMWTypeLight,Bold]BMW Universal Bluetooth[/FONT][FONT=BMWTypeLight,Bold]TM [/FONT][FONT=BMWTypeLight,Bold]Hands-Free Kit
[/FONT][FONT=Arial,Bold]2
[/FONT][FONT=BMWTypeLight,Bold]PARTS INFORMATION:
[/FONT][FONT=BMWTypeLight,Bold]Description Qty BMW Part Number
[/FONT]
ULF Control Module 1 84 21 6 934 552
Voice Input System Jumper Plug 1 84 11 0 018 038
ULF Control Module Mounting Bracket (Touring) 1 84 13 6 924 698
E46 Sedan/Coupe/Touring Installation Kit 1 84 11 0 302 639
[FONT=BMWTypeLight,Bold]Installation Kit Contents:
[/FONT]
M5 Bolt w/washer 6 07 11 9 902 932
M5 Hex Nut 6 63 21 1 371 401
M5 Clip Nut 4 61 13 1 372 033
Wire tie 2 61 13 1 367 599
(if rear carrier brackets are installed)
1 84 13 6 924 553
Microphone 1 84 31 8 380 319
Bluetooth
TM Antenna 1 84 50 6 928 461
BluetoothTM Antenna Mounting Bracket 1 84 13 6 912 160
Pairing Button 1 84 13 0 302 715
Adapter Harness 1 84 11 0 302 181
ULF Pairing Button Cutout Template 1 84 11 0 304 482
ULF Owner’s Manual 1 84 11 0 302 638
ULF Passkey Reference Card 1 84 11 0 302 646
ULF E46 Installation Instructions 1 84 11 0 302 643
Owner’s Manual For Voice Input System 1 84 11 0 027 942
[FONT=BMWTypeLight,Bold]PROCEDURE:
[/FONT][FONT=BMWTypeLight,Bold]To install and connect the BMW Universal Bluetooth
[/FONT][FONT=BMWTypeLight,Bold]TM [/FONT][FONT=BMWTypeLight,Bold]Hands-Free System
[/FONT]
Disconnect Battery prior to starting the installation.
[FONT=BMWTypeLight,Bold]A. Bluetooth
[/FONT][FONT=BMWTypeLight,Bold]TM [/FONT][FONT=BMWTypeLight,Bold]Antenna & Pairing Button Installation
[/FONT]
1. Remove the rear ashtray and disconnect the
illumination light (2).
2. Remove two Phillips screws (3) and remove the
rear ashtray assembly (1).
[FONT=Arial,Bold]3
[/FONT]
3. Remove the center console storage tray (2), refer
to RA 51 16 200.
The center console will need to be removed in
order to install the pairing button later in the
procedure.
4. Locate the black FAKRA connector (1), located
below the rear ashtray assembly.
5. Secure the Bluetooth
TM antenna (D),
P/N 84 50 6 928 461, to the antenna-mounting
bracket (C), P/N 84 13 6 912 160, using two M5
hex nuts (J), P/N 63 21 371 401.
6. Connect the black FAKRA connector (1) to the
antenna (D).
7. Place the mounting bracket with antenna (1) on
top of the mounting points.
[FONT=Arial,Bold]4
[/FONT]
8. In order to install the Pairing Button,
P/N 84 13 0 302 715, an opening must be cut
into the rear of the center console. The area to be
cut out can be marked using the template
P/N 84 11 0 304 482
9. Cut out the template as indicated and fold one
side of the template
10. Place the template (1) onto the center console.
11. Secure the template in place by taping the edges
of the template to the console as shown (2).
12. Mark the area to be cut out using a pencil
13. The cut out can be made using a rotary cutting
tool (1) with a high-speed cutting bit attachment.
14. Use the following measurements to properly
center the switch opening if not using the
template:
Measurement A = 33 mm (From inside
corner/edge to locate the left side of the switch
opening)
Measurement B = 25 mm (Establish the length
of the opening)
15. Marking cut out continued:
Measurement D = 7 mm (From leading edge, to
establish the forward edge of the switch
opening).
Measurement C = 16 mm (Define the width of
the switch opening).
16. Carefully cut out the marked rectangle. Use a
small file to clean up the edges and enlarge the
opening as necessary.
[FONT=Arial,Bold]5
[/FONT]
17. Carefully reinstall the center console.
18. Reinstall the top panel (1) and reinstall the two
Phillips head screws (3) making certain that they
go all the way down through the antennamounting
bracket to the clip nuts.
19. Locate the black 18-pin connector X4545 in
bundle (1).
20. Connect the interface harness (2),
P/N 84 11 0 302 181, to X4545 (3).
21. Route the end of the interface harness (2) with the
white 3-pin connector through the cutout in the
console.
22. Connect the pairing button (1),
P/N 84 13 0 302 715, to the interface harness (2).
[FONT=Arial,Bold]6
[/FONT]
23. Insert the Pairing Button, P/N 84 13 0 302 715,
into the cutout and reinstall the cupholders and
coin tray.
[FONT=BMWTypeLight,Bold]B. ULF Control Module Installation
[/FONT]
1. Remove/ peel off the Bluetooth
TM Passkey sticker
(2) from the label on the ULF Control Module (1).
2. Place the BluetoothTM Passkey sticker removed
from the ULF Control Module onto the ULF
Passkey Reference Card, P/N 84 11 0 302 638.
3. Place this card inside the owner’s manual
portfolio. Show this card to the customer when
demonstrating the system and the pairing
procedure to the customer. The code on the
sticker is needed to pair phones to the ULF
Control Module.
[FONT=Arial,Bold]7
[/FONT][FONT=BMWTypeLight,Bold]E46 Touring
[/FONT]
1. Attach the ULF Control Module (F) to the
mounting bracket (G), P/N 84 13 6 924 698; use
three M5 hex nuts (J), P/N 61 21 1 371 401.
2. Locate the black 54-pin connector and white
FAKRA connector, bundled near the left rear
wheel hub.
NOTE: If a navigation unit (2) and/ or CD
changer is installed it will need to be removed, in
order to gain access to the inner portion of the
left rear quarter panel.
3. Carefully pull back on the felt panel (1) to gain
access to the inner area of the rear quarter panel.
[FONT=Arial,Bold]8
[/FONT]
4. Prior to connecting the black 54-pin connector to
the ULF Control Module pins 7 & 8 will need to be
removed from the connector and tied back.
Note: Pins 7& 8 provide a wheel speed input
signal that is not utilized by the ULF Control
Module and need to be disconnected from the
control module.
5. Open the connector by pushing out on the lock
tap(s) (1) and slide the terminal housing (2) out of
the connector housing.
6. Locate pins 7 & 8 (2) and carefully remove them
from the terminal housing (1).
7. Bend the wires for pin 7 & 8 back away from the
connector
8. Wrap each terminal separately with electrical tape
and tape them to the wiring harness.
9. Reassemble the connector.
10. Connect the 54-pin connector (2) and white
FAKRA connector (1) to the ULF Control Module
(F).
[FONT=Arial,Bold]9
[/FONT]
11. Insert the ULF Control Module and bracket (1) into
the opening in the inner area of the rear quarter
panel, and place the bracket against the inner
portion of the support structure.
12. The three threaded lugs on the mounting bracket
should be inserted through the three holes in the
support structure (2).
13. Secure the bracket (G) in place using three M5
hex nuts (J), P/N 63 21 1 371 401.
14. Reinstall the felt panel (1) and components
removed previously.
[FONT=Arial,Bold]10
[/FONT][FONT=BMWTypeLight,Bold]E46 Sedan with Carrier Rack
[/FONT]
1. If the left rear of the trunk is as shown, then a
component carrier rack is already installed and the
following steps should be followed.
2. If the trunk is not as shown refer to the installation
steps for no carrier rack installed, on page 12.
3. Remove the left rear trim panel.
4. Locate the black 54-pin connector and white
FAKRA connector bundle (1), near the left rear
wheel well housing.
5. Route the 54-pin connector and white FAKRA
connector along the right side of the component
carrier rack (2), making certain that the 54 pin
connector and white FAKRA connector can be
connected to the ULF Control Module as
indicated in the following steps.
6. Prior to connecting the black 54-pin connector to
the ULF control Module pins 7 & 8 will need to be
removed from the connector and tied back. (Wires
are only present on vehicles produced as of 8/02)
control module.
7. Open the connector by pushing out on the lock
[FONT=Arial,Bold]11
[/FONT]
8. Locate pins 7 & 8 (2) and carefully remove them
9. Bend the wires for pin 7 & 8 back away from the
connector
10. Wrap each terminal separately with electrical tape
11. Reassemble the connector.
12. Attach the ULF Control Module (F) to the
mounting bracket (H) P/N 84 13 6 924 553 using
three M5 hex nuts (J) P/N 63 21 1 371 401.
13. Install the ULF Control Module-mounting bracket
(H) using four clip nuts P/N 61 13 1 372 033,
which need to be placed onto the left and right
carrier bracket in order to install the four M5 Hex
bolts (K), P/N 07 11 9 902 932.
[FONT=Arial,Bold]12
[/FONT]
14. Connect the 54-pin connector (2) and white
(F) after the bracket is installed.
15. Reinstall the left rear trim panel.
[FONT=BMWTypeLight,Bold]E46 Sedan With No Carrier Rack
IMPORTANT:
[/FONT]In the event a vehicle is not equipped
with a carrier bracket the trunk will look as indicated in
the illustration.
1. Remove left rear trim panel.
2. Remove the securing bolt (1) for the amplifier
securing bracket and the clip-nut
3. Locate the telephone connector bundle (2).
[FONT=Arial,Bold]13
[/FONT]
6. Attach the two clip nuts (1 & 2), P/N 61 13 1 372
033, to the ULF Control Module as shown.
7.
[FONT=BMWTypeLight,Bold]For E46 vehicles produced prior to 8/02
continue with step 14.
[/FONT]
8.
[FONT=BMWTypeLight,Bold]For E46 vehicle produced as of 8/02 only:
[/FONT]
removed from the connector and tied back (Pin 7
& 8 are only used on vehicles produced as of
8/02)
Module and will need to be disconnected from
the control module.
9. Open the connector by pushing out on the lock
10. Locate pins 7 & 8 (2) and carefully remove them
[FONT=Arial,Bold]14
[/FONT]
11. Bend the wires for pin 7 & 8 back away from the
connector
12. Wrap each terminal separately with electrical tape
13. Reassemble the connector.
14. Locate the black 54-pin connector and white
FAKRA connector.
15. Slide the ULF control module (1) into the open
area behind the amplifier.
15. Secure the ULF Control Module (1) to the interior
of the support structure using two M5 hex bolts (2
& 3), P/N 07 11 9 902 932.
16. Reinstall the trim panel
[FONT=Arial,Bold]15
[/FONT][FONT=BMWTypeLight,Bold]C. Installation of Voice Input Jumper
[/FONT]
1. If a Voice Input Jumper Plug is not installed then a
Jumper Plug, P/N 84 11 0 018 038, must be
obtained and installed for the system to function
correctly. The jumper plug should be installed
onto a blue 26 pin connector that is located near
the black 54 pin connector for the ULF module.
Note: The Jumper plug is not included in the kit
as this plug may already be installed on some
vehicles.
[FONT=BMWTypeLight,Bold]D. Installation of Microphone
[/FONT]
1. Carefully pull down the access panel (1).
2. Locate the black 3-pin connector X18507 that is
taped to the harness.
3. Install microphone (E) P/N 84 31 8 380 319, with
the arrow on the microphone pointing to the front
of the vehicle, into the microphone fret and
connect X4221 to the microphone.
4. In the event of a customer complaint indicating
that the outgoing audio from the vehicle sounds
distant, the location of the microphone and
sunroof switch can be reversed to place the
microphone closer to the driver.
[FONT=BMWTypeLight,Bold]Reconnect the Battery
[/FONT][FONT=Arial,Bold]16
[/FONT][FONT=BMWTypeLight,Bold]Coding ULF Control Module to Vehicle
[/FONT]
After installing the ULF Kit, the vehicle should be re-coded with DIS/GT1 SW 33 or higher, using the
“Retrofit” path to ensure that the system works properly with the systems currently installed in the
vehicle. The recoding is done automatically when using the following “retrofit” procedure:
Connect DISPlus or GT1 to vehicle (with SW 33 or higher installed)
Turn on ignition
Select “Coding ZCS”
Series: “E46 Series”
Path: “2 Retrofit”
System: “ULF Universal charging and Handsfree facility”.
Follow the on screen requests to activate the coding procedure.
[FONT=BMWTypeLight,Bold]E. Function test
[/FONT]
Upon completion of the recoding, verify that the BMW Universal Bluetooth
TM Hands-Free System is
working correctly by going through the following action steps. After completing each step ensure that
the desired result is obtained:
[FONT=BMWTypeLight,Bold]Action Response
[/FONT]
Pair phone to vehicle (refer to section for
pairing instructions).
Phone and or Radio/MID/Board Computer
should display statement indicating Pairing
succeeded
Turn on radio and initiate a call using voice
recognition commands by
depressing/holding the Voice recognition
button on steering wheel until an audible
beep is heard
Radio should mute and an audible beep is
heard through vehicle speakers.
Say “Dial number” System states “Please speak the number”
Say phone number to be dialed
ex”1234567890”
System states “1234567890”
If number is correct say “Dial” Call is placed and number being dialed is
displayed on phone as well as on
Radio/MID/Board Computer.
[FONT=Arial,Bold]17
[/FONT][FONT=BMWTypeLight,Bold]F. Troubleshooting:
Situation Correction
[/FONT]
No audio output through vehicle speakers Check SES module jumper plug
Radio does not mute after placing a call Check connections at rear of radio for Tel On and
Tel Mute signal. Verify that connectors and pins
are properly seated.
Audio quality in vehicle may not sound very good
- Recode ULF Control Module.
NOTE: Audio quality in vehicle or at person
being contacted, is dependent on the quality
and signal strength of the wireless service
provider in the area traveled.
Customer complains that the person being
contacted hears a “Buzzing” noise, at times during
their conversation or on voice mail message that
he/she has left.
Intermittently a “Buzzing” noise is noticeable to the
person being called from the vehicle. The
“Buzzing” noise is a result of the GSM signal being
feedback through the microphone, this usually
occurs if the GSM phone is located too close to
the microphone. The customer should change the
location of where the phone is placed/stored.
Driver is told that the person being contacted
complains that there is an echo/reverberation in
the audio; person can hear his/her voice back
through the phone.
Audio volume in vehicle during a call may be a bit
to loud, causing the other person to hear his/her
voice coming back through the phone.
A second call is received while in a call, and call
cannot be accepted using MFL controls.
Use handset to expect second call and place
previous called on hold. Call waiting is functional
only via the handset.
The radio audio does not come back immediately
if the “other” person hangs up first.
It takes approximately 15 seconds for the ULF
system to recognize that the call was terminated
from outside the vehicle.
If the call is terminated from outside the vehicle
first, the driver can depress the button on the
steering wheel to terminate the call from the
vehicle and unmute the radio quicker.
Customer is not able to pair phone to system, not
able to locate ULF passkey/password reference
card.
The “BluetoothTM Passkey” is identified on the
label of the ULF Control Module located in the
rear of the vehicle.
The “BluetoothTM Passkey” for the installed
control module can be obtained by connecting
the DISPlus or GT1and accessing the
diagnostics for the ULF system:
- select “Diagnostic requests”
- select “Bluetooth code”
Intermittently a popping noise is audible through
the vehicles speaker and there is no BluetoothTM
wireless communication established between the
ULF module and the phone.
Vehicle and /or ULF Control Module are not
correctly coded.
Recode module and vehicle (refer to Coding
ULF Control Module to Vehicle)
E46 Only:
After installation of ULF system the speedometer
and odometer do not work.
Remove pin 7 & 8 from the 54-pin connector
going to the ULF Control Module. Refer to the
E46 installation instructions.
[FONT=Arial,Bold]18
[/FONT][FONT=BMWTypeLight,Bold]G. Pairing Procedure:
[/FONT]
The pairing procedure that must be initiated through the phone will differ corresponding to the different
menu configurations of the various Bluetooth
TM mobile phones on the market. The user’s manual of the
phone should always be referenced for specific steps on how to activate the BluetoothTM feature and to
pair/link devices.
The following steps are generalized steps that should help in activating the BluetoothTM function of most
phones:
[FONT=BMWTypeLight,Bold]IN VEHICLE:
[/FONT]
1. Depress the pairing button for at least 1
second prior to switching on the ignition and
continue to hold the button down for
approximately 2-3 seconds after the ignition is
turned on.
2. Release the button.
3. Shortly after releasing the button the Radio or Board Monitor display should look like one of the
following:
a. Board Monitor Display:
“Bluetooth Pairing” displayed.
Green, Yellow and Red LEDs on the
right side of the unit are flashing which
indicates that the ULF is searching for
available BluetoothTM devices.
b. Radio Display:
“BT Pairing” display which indicates
that the ULF is searching for available
4. Activate the search function of the phone as indicated below.
[FONT=BMWTypeLight,Bold]ON PHONE:
[/FONT]
1. Locate the connection/settings menu and select Bluetooth
TM.
2. Select the response that will activate the BluetoothTM feature of the phone.
3. Next select a menu option that will allow you to “Discover” or “Search” for active BluetoothTM
devices.
[FONT=Arial,Bold]19
[/FONT]
4. If the phone identifies/finds a device select it and follow the indicated steps to complete the pairing
process.
5. Once the phone is successfully paired to the device cycle the ignition switch off and back on and the
devices should wirelessly connect within 30 seconds. When the connection is established the
phone will display a connection symbol.
The following steps are an example of the pairing procedure that must be initiated to pair the Sony
Ericsson T68i phone to the ULF Control Module.
1. Press the menu button.
2. Select “Connect”.
3. Select option 3: “Bluetooth”.
4. Select option 4: “Options”.
5. Select option 1: “Operation mode” and set to “On” or “Automatic”.
6. Go back one step by pressing the red phone button.
7. Select option 3: “Discover”.
Mobile Phone display shows ‘Searching’
8. Select “BMW ……” in upcoming list.
9. Select option 1: “Add to paired”.
10. Enter password (= ULF passkey) located on ULF Control Module in the rear of the vehicle or on the
Passkey Reference Card.
Mobile Phone display shows ‘BMW …… Pairing’
Mobile Phone display shows ‘Pairing Successful’
Board Monitor display shows ‘Pairing succeeded’ for 3 seconds
11. Enter device name.
12. Mobile Phone display shows “Added to paired devices”.
13. Quit menu by pressing the red phone/NO button for several seconds.
14. Once the phone is successfully paired to the
on.
15. The devices should wirelessly connect within
30 seconds. The connection is established
when the phone displays the symbols
indicated, on the right side of the screen.
Note: Shortly after turning on the ignition and the BluetoothTM connection is identified, the phone
may display a message asking if the connection should be established/accepted. The connection
authorization request will always occur unless the setting on the phone is modified to allow
automatic connection every time, please refer to the user’s manual of the phone to determine how to
change this setting.
[FONT=Arial,Bold]20
[/FONT][FONT=BMWTypeLight,Bold]COMPONENT LOCATION:
SPORT WAGON
SEDAN
[/FONT]
A - Eject Box C/E - Microphone
D - Bluetooth
TM Antenna F - ULF Control Module
[FONT=Arial,Bold]21
[/FONT]
Speaker
Tel +
Tel -
Telephone Mute
Telephone On
X10015
2 1 13
Cradle Key +
Cradle On
X4545
X4545
Bluetooth
Antenna
I/K Bus
to other modules
from terminal 30 from terminal R
3
Light
Switch
input
F39
5A
X01185
X01185
Microphone
2 3 1
Microphone +
Microphone -
Microphone Shield
X18507
output
to
speaker
F41 F7
X13649
SES
Jumper
Plug
X13016
ULF Wiring Schematic for the E46
with Boardmonitor
ULF
Control
Module
Radio
Control
Module
Interface
Switch
6 12 11 10 15 16
12
17 35 32 11
36 21 19 1 37 38 33 51 15
26 25 23
8 9 13 12 18
10 11
+5V
not in use
X13016
2 3 1
X2759
F7
5A
X9987
X9988
30 R
X13016
Ground Distribution
Schematic information
obtained / developed using
schematics from DIS v 32.0
I/K Bus
X10016
X10390
X10390
Boardmonitor
X13649
X18801
TAPEL -
TAPEL +
TAPER -
TAPER + 2
4
1 8
3 9 10
7
6
9
X13646
to other modules
X13646
X13646
F41 F7
7 11 1
Light
Switch
input
X13016
2
X18801
[FONT=Arial,Bold]22
[/FONT]
Speaker
Tel +
Tel -
Telephone Mute
Telephone On
X10015
2 1 13
Cradle Key +
Cradle On
X4545
X4545
Bluetooth
Antenna
I/K Bus
to other modules
3
Light
Switch
input
F39
5A
X01185
X01185
Microphone
2 3 1
Microphone +
Microphone -
Microphone Shield
X18507
output
to
speaker
Light
Switch
input F41 F7
X13321 X18126
X18126
SES
Jumper
Plug
X13016
without Boardmonitor
ULF
Control
Module
Radio
Control
Module
Interface
Switch
8 3 10 4 13 9 5 7
15
17 35 32 11
26 25 23
8 9 13 12 18
10 11
+5V
not in use
X13016
2 3 1
X2759
F7
5A
X9987
X9988
30 R
X13016
Ground Distribution
I/K Bus
X10016
X10390
X10390
