Tabla de fallos y sus causas
Tema en 'Serie 3 (E46) (1998-2007)' iniciado por Salao, 28 Feb 2006.
  1. Salao
    Salao Forista
    9 Nov 2005
    Mirando el porque de los tirones en mi 330XD vi esta tabla y me parecio interesante.
    La dejo en ingles por las interpretaciones en la traduccion.
    Table e. Engine Driveability Trubleshooting
    SYMPTOMS
    • Engine fails to start
    • Engine starts but stops immediately
    • Erratic engine idle
    • Poor engine response on acceleration
    • Erratic engine operation in all speed ranges
    • Excessive fuel consumption
    • Poor engine power, fails to rev up
    • CO content too low
    • CO content too high
    a
    b
    c
    d
    e
    f
    g
    h
    i
    CAUSES
    CORRECTION ACTION
    a
    Fuel pump faulty
    Test fuel pump. Repair Group 160
    a
    e
    Ignition system faulty
    Test ignition system. Repair Group 120
    a
    Main relay or fuel pump relay faulty
    Test main relay. Repair group 130
    a
    Crankshaft/rpm position sensor faulty
    Test crnkshaft/rpm sensor 120
    b
    c
    h
    i
    Idle speed control valve faulty
    Test idle speed control valve
    c
    d
    e
    Throttle position sensor faulty or idle signal to DME control module missing
    Test throttle position sensor
    c
    d
    h
    i
    Mass air flow sensor faulty
    Test mass air flow sensor Repair Group 130
    a
    b
    c
    d
    e
    h
    Large air intake system leak
    Check for major intake air leaks downstream of mass air flow sensor
    a
    c
    d
    e
    g
    h
    Fuel pressure too low
    Test fuel pressure. Repair Group 130
    c
    f
    I
    Fuel pressure too high
    Fuel pump delivery volume too low
    Test fuel pump delivery volume. Repair Group 160
    a
    c
    e
    f
    h
    i
    Coolant temperature sensor faulty
    Test coolant temperature sensor
    c
    f
    Oxygen sensor faulty
    Test oxygen sensor.
    c
    e
    f
    i
    Fuel injectors leaking
    Check fuel injectors and replace leaking injectors Repair Group 130
    c
    Throttle plate binding or incorrectly adjusted
    Check throttle plate and adjust necessary
    a
    c
    Electrical connections loose, broken or corroded
    Visually inspect connectors and correct any faults. Repair Group 600
    a
    c
    d
    Ground connections loose, broken, or corroded
    Visually inspect ground connections and correct any faults. Repair Group 600
    c
    e
    f
    CO content too high
    Test air flow or mass air flow sensor. Repair Group 130
    a
    b
    c
    d
    e
    g
    CO content too low
    b
    c
    d
    e
    f
    g
    h
    i
    Input signals to ECM missing ECM in limp home mode
    Make electrical tests at DME ECM relay. Repair Group 130a
    a
    b
    c
    d
    e
    f
    g
    h
    i
    ECM faulty
    Test DME ECM inputs, If all inputs are correct replace ECM
  2. Salao
    Salao Forista
    9 Nov 2005
    Vaya no ha salido la tabla tal y como la tenia .
    La enviare en fichero PDF
    Lo siento
  3. Salao
    Salao Forista
    9 Nov 2005
  4. Salao
    Salao Forista
    9 Nov 2005
