Fotos BMW Z8 cumple 20 años
BMW Z8 (E52): 20 years since the rebirth of an icon
September 26, 2020
The Z8 is one of the most spectacular roadsters that BMW ever built, embodying powerful styling cues from the original 507 of the ’50s into a modern, timeless design. The automotive world got an indication of BMW’s serious plans when the Bavarians introduced the Z07 concept in 1997 at the Tokyo Motor Show. The roadster show prototype was immediately labelled as a profound tribute to the classic 507 Roadster.
Two years later, at the IAA Frankfurt 1999 edition, BMW officially premiered the series model inspired by the Z07 showcar: the Z8. Both the 1997 concept and the serial-production model were penned by the famous designer Henrik Fisker, under the strict guidance of the equally-renowned Chris Bangle.
The BMW Z07 Concept of 1997.
The then-new BMW Z8 was exclusively powered by the 4,941-cc BMW S62 V8 engine also installed in the E39 M5 generation. The peak output of 295 kW / 400 PS (394 hp) reaches the rear-axle wheels chaneled through a 6-speed manual transmission.
In proper BMW policy, the Z8 achieved the ideal 50:50 weight distribution over the two axles. The powertrain was further enhanced with the standard DSC system and an auto-lock rear differential. The Z8 also premiered the tire pressure control function, a real novelty in the automotive industry at that time.
Furthermore, the E52 model series was the first pan-European model to be fitted with run-flat tires. All in all, the fitted drivetrain was able to propel the Z8 from standstill to 100 km/h in just 4.7 seconds, whereas the top speed was electronically limited to 250 km/h.
Up to summer 2003, when the production ceased, exactly 5,703 units of the Z8 have been manually assembled at the home plant in Munich in a specially-developed facility, further highlighting the exclusive status of the E52 roadster model.
ALPINA also took the Z8 to convert into the limited-edition BMW ALPINA Roadster V8. Produced in just 555 examples, the Buchloe-tuned Z8 was powered by the BMW M62 8-cylinder engine instead of the S62, which produces a peak output of 280 kW / 381 PS (375 hp). The M62 engine, coded ALPINA F5, also powered the ALPINA B10 V8 S model based on the E39 5 Series.
During its short career, the Z8 Roadster also served as Official Safety Car of the MotoGP competition during the 2001 – 2003 seasons, also employing a fixed, rigid roof to ensure a higher level of security and to allow for the installation of the light panel.
Last, but not least, the Z8 gained further appeal and raised fans awareness by starring in the Bond series and being driven by Pierce Brosnan as James Bond in the 1999-released “The World Is Not Enough” movie.
Albrecht von Goeritz, designer of the legendary 507 Roadster, said in 2003 about the Z8: “If I had to design the BMW 507 now, it would be like the BMW Z8.” This pretty much sums up everything about the E52 series.
Certainly, as roadsters become more and more of a rarity, with the Z4 rumored to be facing the axe after the current G29 generation, it is only a matter of years until the modern BMW open-top two-seaters will become modern classics one day. They will then join a rich gallery of roadsters, that also includes the Z3, the Z1 and the 315/1 forerunner model.
The Z8 is surely very close to this milestone, as it is a real, highly sought after collectors’ gem.
BMW Z8 (E52): 20 años desde el renacimiento de un icono
26 de septiembre de 2020
El Z8 es uno de los roadsters más espectaculares que jamás haya construido BMW, incorporando poderosas señales de estilo del 507 original de los años 50 en un diseño moderno y atemporal. El mundo del automóvil se dio cuenta de los planes serios de BMW cuando los bávaros presentaron el concepto Z07 en 1997 en el Salón del Automóvil de Tokio. El prototipo del roadster show fue inmediatamente etiquetado como un homenaje profundo al clásico 507 Roadster.
Dos años después, en la edición de 1999 de la IAA Frankfurt, BMW estrenó oficialmente el modelo de serie inspirado en el showcar Z07: el Z8. Tanto el concepto de 1997 como el modelo de producción en serie fueron escritos por el famoso diseñador Henrik Fisker, bajo la estricta guía del igualmente renombrado Chris Bangle.
El BMW Z07 Concept de 1997.
El entonces nuevo BMW Z8 estaba propulsado exclusivamente por el motor BMW S62 V8 de 4.941 cc, también instalado en la generación E39 M5. La potencia máxima de 295 kW / 400 PS (394 hp) llega a las ruedas del eje trasero canalizadas a través de una transmisión manual de 6 velocidades.
En la política adecuada de BMW, el Z8 logró la distribución ideal de peso 50:50 en los dos ejes. El tren motriz se mejoró aún más con el sistema DSC estándar y un diferencial trasero de bloqueo automático. El Z8 también estrenó la función de control de presión de los neumáticos, una verdadera novedad en la industria automotriz en ese momento.
Además, la serie de modelos E52 fue el primer modelo paneuropeo en equiparse con neumáticos run-flat. Con todo, el tren motriz equipado fue capaz de propulsar el Z8 desde parado a 100 km / h en solo 4,7 segundos, mientras que la velocidad máxima se limitó electrónicamente a 250 km / h.
Hasta el verano de 2003, cuando cesó la producción, se habían ensamblado manualmente exactamente 5.703 unidades del Z8 en la planta de origen de Múnich en una instalación especialmente desarrollada, lo que resalta aún más el estatus exclusivo del modelo roadster E52.
ALPINA también tomó el Z8 para convertirlo en el BMW ALPINA Roadster V8 de edición limitada . Producido en solo 555 ejemplares, el Z8 ajustado por Buchloe fue impulsado por el motor BMW M62 de 8 cilindros en lugar del S62, que produce una potencia máxima de 280 kW / 381 PS (375 hp). El motor M62, codificado ALPINA F5, también impulsó el modelo ALPINA B10 V8 S basado en la Serie E39 5.
Durante su corta carrera, el Z8 Roadster también sirvió como coche de seguridad oficial de la competición de MotoGP durante las temporadas 2001-2003, empleando también un techo rígido fijo para garantizar un mayor nivel de seguridad y permitir la instalación del panel de luces.
Por último, pero no menos importante, el Z8 ganó más atractivo y aumentó la conciencia de los fanáticos al protagonizar la serie Bond y ser conducido por Pierce Brosnan como James Bond en la película "El mundo no es suficiente" estrenada en 1999.
Albrecht von Goeritz, diseñador del legendario 507 Roadster, dijo en 2003 sobre el Z8: "Si tuviera que diseñar el BMW 507 ahora, sería como el BMW Z8". Esto resume bastante bien todo sobre la serie E52.
Ciertamente, a medida que los roadsters se vuelven cada vez más raros , y se rumorea que el Z4 se enfrentará al hacha después de la actual generación G29 , es solo cuestión de años hasta que los modernos BMW descapotables biplaza algún día se conviertan en clásicos modernos. . Luego se unirán a una rica galería de roadsters, que también incluye el modelo Z3, Z1 y 315/1 forerunner.
El Z8 seguramente está muy cerca de este hito, ya que es una verdadera joya de coleccionista muy buscada.
Un bellezón en toda regla, felicidades :chulo:
Otro de los coches con 20 años muy interesantes :finga:
También fue coche Bond, como el Z3 , hay que reconocer que 007 tiene buen gusto :chulo:
-ENRI-
Ex E46, 718
30 Jul 2006
A estos también habría que invitarlos a la fiesta..
