Catálogo Evo X
Dixi
5 Ago 2003
Pinchad aquí
Fuente: http://carscoop.blogspot.com/2007/08/2008-mitsubishi-lancer-evo-x-brochure.html
While we’re waiting to see if Mitsubishi will unveil the new 2008 Lancer EVO X (high-res images of the production version here) at the Frankfurt Show next month or at the Tokyo Show in October, an official brochure of the Japanese-spec version has been leaked into the web revealing several details on the car. Most importantly, we learn that the Lancer EVO X’s new lightweight 2.0-liter turbocharged MIVEC*4 engine delivers 206 kw which translates to 280 PS or, 276 HP @ 6.500 rpm and a maximum torque figure of 422 Nm (311 lb.ft or 43.0 kgm) @ 3.500 rpm. Comparatively, the 4G63 2L DOHC intercooled 2.0L turbo engine used in the outgoing Lancer EVO IX had the same output of 206 kW (280 PS) at 6,500 rpm, but a lower maximum torque figure of 400 Nm (295 lb.ft or 40.8 kgm) at 3,000 rpm for the 6-speed M/T GSR, and 407 Nm (300 lb.ft or 41.5 kg-m) at 3,000 rpm for the 5-speed M/T RS. Of course, since these figures concern the JDM version, we’ll have to wait to see what Mitsubishi has in mind for the European and US versions spec versions. -Continued after the jump
Albeit it’s virtually impossible to translate the 27 page long brochure, we managed to make out a few things including the fact that the Lancer EVO X will be available in Japan in two versions, the GSR and the RS. The GSR will be offered either with Mitsubishi’s new 6-speed dual-clutch gearbox (read more about that here) or with a 5-speed manual. The RS will be available solely with the 5-speed manual gearbox. After you check out the brochure check out high-res official images of the JDM spec Lancer EVO X by clicking here.
Source: Lancerregister , Via: Autoblog.nl
k-noso
20 Nov 2002
graciasssssssssssssssssssssssssssssssssss
FLYNN
Yes we Clann
M3 e46
21 Nov 2005
Precioso, realmente precioso. :notworthy::notworthy:
romeodj
18 May 2006
pues que quereis que os diga.........para mi es el EVO mas feo de todos
Targa
5 Abr 2007
no me gusta nada. se me da un aire al Alfa GT
Fer_gm
20 Mar 2007
el catalogo se entiende de p*ta madre!:twitcy:
M
micro488
Tuve un EVO III alla por el año 96. Que pedazo de maquina !!!
Jesús Fco.
11 Abr 2003
A mi me gustaban mucho mas los que van del 5 al 9.... pero para gustos los colores... Tambien me cabreaba el cambio que le pegó bangle al serie 5 E60... con lo bonito que era el E39... y ahora si lo veo negro y con unas buenas llantas ya lo veo mucho menos feo...
Este evo parece que lo haya diseñado walter da silva¡¡¡. Esperaremos a verlo en vivo y en directo, pero mi primera impresion es como un restilyng de un alfa 159 o algo asi.... en fin, no es lo que me esperaba de mitsubishi y eso de que monte motor vag en los diesel ya me ha terminao de matar¡¡¡
Gracias Dixi! Me gusta mucho tambien el nuevo Evo: lástima que al final las dimensiones no sean tan contenidas como el concept Evo...se ha ido a 4,60 m , tambien :???: Menos mal que como pepino de tamaño contenido existe el 135i :supz:
