Video Toyota GR Yaris vs Porsche Cayman 718 GT4 en Nürburgring
NÜRBURGRING NORDSCHLEIFE
GR Yaris gives a Porsche 718 GT4 a run for its money on the Nürburgring!
25 mar 2022
GreatMotors
Very good day to be on track, dry weather with not too much cold. Taking a friend made in the parking lot for his first quick lap around the Nürburgring with the GR Yaris. The semi-slick tires were warmed up and the brakes were also performing at their peak! Unfortunately some drivers don't know when to get out of the way despite being clearly signaled to do so. It was still nice to see the GT4 move around but I wish the driver was more respectable and would have gotten out of the way at some point. Enjoy!
Timestamps:
00:00 - Intro
00:32 - Bridge to Gantry
09:32 - Final Thoughts
: Car: Toyota GR Yaris
: Power: Stock 261HP 360Nm
: Gearbox: 6-Speed Manual
⚖️: Weight: 1310Kg EG
♂️: Passengers: 90kg
: Tires: 225/40/18 Michelin Pilot Sport Cup 2 ( 5000km driven. 35% of life left)
: Autec Wizzard 8x18" ET35mm (10mm wider than stock)
: Brakes: Motul RBF 660 + Braided Brake Lines + Endless ME22 Pads
: Suspension: KW Clusbsport (with alignment)
: Weather: 10°C + Overcast
718 Cayman GT4 Owner fails to shake off Toyota GR Yaris on the Nürburgring!!
9 jul 2021
GreatMotors
Warm weather and weekend is a recipe for A LOT of traffic!!
This beautiful Porsche 718 GT4 caught up to me due to traffic ahead and decided that tailgating me was his best option. I move to the side ASAP and then went after him. Stay put for some funny comments biggrin!
♂️+‍♂️: Passengers: 90kg + 80kg
: Tires: 225/40/18 Michelin Pilot Sport Cup 2 ( 1500km driven. Good condition)
: Wheels Autec Wizard 8x18J ET35 (20mm per Axis wider than OEM)
: Suspension: Stock (with alignment)
: Weather: 28°C + SUN (Dry)
Timestamps:
00:00 - Intro
00:16 - Start of the Lap
02:40 - Yellow
03:35 - GR Lapping :)
05:40 - Porsche gets close
06:30 - Porsche overtakes
09:55 - End of Lap
julfost
Que bien va la pelotilla y que fustre para el Cayman :LOL:
Menos entiendo aún que los periodistas se quejen de barqueo y se queden, en carretera abierta, sin frenos en el Supra. Algo no me cuadra en esto
inthenight
19 Feb 2005
Más de 100cv de diferencia y no habrá ni 150kg de diferencia… El chiste se cuenta solo.
Las manos y experiencia en el ring hacen mucho...
Una de 6 cilindros... 3+3 biggrin
Toyota GR Yaris SQUARED on the Nurburgring. Cool Lead-Follow lap!
24 dic 2021
GreatMotors
I had a great time doing this lap. Met the owner of the GR Yaris on the parking lot and asked him if he would like to go for a lap together. His car looked fantastic, and had lots of the mods I would do to mine if I was running on an unlimited budget. Still super satisfied with mine!
Timestamps:
00:00 - Intro
01:26 - Bridge to Gantry
09:58 - Final Thoughts
GR #1 (mine) :
: Tires: 225/40/18 Michelin Pilot Sport 4 S ( 3300km driven. 65% of life left)
: BBS Forged wheels (stock)
GR #2 (the other) :
: Power: Engine Stock 261HP 360Nm (+200 CELL DownPipe + Exhaust)
⚖️: Weight: 1310Kg EG (- Interior; Recaro Poleposition; +Cage)
♂️: Passengers: ??kg
: Tires: 225/40/18(?) Michelin Pilot Sport Cup 2
: Brakes: Stock with mods (?)
RAZGRIZ
123d E81
20 Jul 2008
El yaris va que se las pela.
Ponedme un cayman.
Este Porsche 718 Cayman GT4 no puede sacudirse un Toyota GR Yaris en el 'Ring'
23 DE ABRIL DE 2022
Toyota no ha establecido un tiempo de vuelta oficial en Nurburgring para el GR Yaris , pero si lo hiciera, sospechamos que podría estar a la altura de algunos de los hatchbacks más rápidos que jamás hayan recorrido el famoso circuito alemán. Cuando está en las manos adecuadas, incluso puede hacer que algunos autos deportivos mucho más caros corran por su dinero.
El propietario de un GR Yaris recientemente llevó la escotilla al 'Ring y durante toda la vuelta pudo seguir de cerca un Porsche 718 Cayman GT4. Por supuesto, esto es más una demostración de habilidad de conducción por parte del tipo detrás del volante del Toyota, ya que, con un conductor más hábil al volante, el Porsche habría corrido en la distancia.
La mejor manera de comparar el rendimiento del 718 Cayman GT4 con el del GR Yaris es mirar la lista de tiempos de Nurburgring de Sport Auto, ya que ha probado ambos autos de forma independiente con el mismo conductor. En mayo de 2020, Christian Gebhardt recorrió el circuito en 7 minutos y 32 segundos con el Porsche, alcanzando una velocidad máxima de 279 km/h (173 mph) en el proceso.
En comparación, Gebhardt necesitó 8 minutos y 14,9 segundos para completar una vuelta del 'Ring con el GR Yaris cuando lo probó en mayo de 2021. Durante esa vuelta, el auto compacto alcanzó una velocidad máxima de 228 km/h (141 mph) .
Para ayudar al GR Yaris a desempeñarse tan bien como lo hace, se encuentra un motor turbocargado de tres cilindros y 1.6 litros que genera hasta 268 hp y 273 lb-ft (370 Nm) de torque según las especificaciones japonesas. Este motor está acoplado a una transmisión manual de seis velocidades y un sistema de tracción permanente en las cuatro ruedas, lo que permite que la escotilla alcance las 62 mph (100 km/h) en solo 5,2 segundos.
This Porsche 718 Cayman GT4 Can’t Shake A Toyota GR Yaris At The ‘Ring
APRIL 23, 2022
Toyota has not set an official Nurburgring lap time for the GR Yaris but if it did, we suspect it could be right up there with some of the quickest hot hatches to ever lap the famed German circuit. When in the right hands, it can even give some much more expensive sports cars a run for their money.
The owner of one GR Yaris recently took the hatch to the ‘Ring and throughout the entirety of the lap, was able to closely follow a Porsche 718 Cayman GT4. Of course, this is more of a display of driving skill on the part of the guy behind the wheel of the Toyota as, with a more skilled driver behind the wheel, the Porsche would have sprinted off into the distance.
The best way to compare the performance of the 718 Cayman GT4 to that of the GR Yaris is to look at Sport Auto’s list of Nurburgring times as it has independently tested both cars with the same driver. In May 2020, Christian Gebhardt lapped the circuit in 7 minutes and 32 seconds with the Porsche, hitting a top speed of 279 km/h (173 mph) in the process.
By comparison, Gebhardt needed 8 minutes and 14.9 seconds to complete a lap of the ‘Ring with the GR Yaris when he tested it in May 2021. During that lap, the hot hatch reached a top speed of 228 km/h (141 mph).
Helping the GR Yaris perform as well as it does is a 1.6-liter turbocharged three-cylinder engine that pumps out up to 268 hp and 273 lb-ft (370 Nm) of torque in Japanese specification. This engine is coupled to a six-speed manual transmission and a permanent four-wheel drive system, allowing the hatch to hit 62 mph (100 km/h) in just 5.2 seconds.
