Comparativa BMW i8 vs Porsche 911, por AUTOCAR
Le mans
5 Dic 2013
Comparison: New BMW i8 vs Porsche 911
Can the i8 plug-in hybrid, the most sophisticated BMW ever, make Porsche's 911 feel outdated?
Porsche's sports car standard-bearer takes on BMW's futuristic performance hybrid
You might have already read our first drive verdict on the BMW i8 and think you know what direction this test is set to take: the Porsche 911 walks it.
However, the i8 is one of the most advanced road cars ever: carbonfibre construction, plug-in hybrid driveline, myriad drive modes, the capability to run in either zero-emissions electric front-wheel drive or petrol-electric four-wheel drive, two gearboxes… the list goes on. It is the most sophisticated car ever to wear a BMW badge.
Next to it, the Porsche appears rather conventional. You wouldn’t call it old-fashioned, even if the 50th Anniversary Edition example driven here plays up its heritage with some throwback stylistic elements, but its mechanical package is nowhere near as contemporary as the i8’s. It is essentially a Carrera S with the wide body of the Carrera 4 and 20-inch wheels that evoke Porsche’s classic Fuchs rims.
At 4689mm long, 1942mm wide and 1293mm high, the i8 has the proportions of a mid-engined car, which it is – at least as far as its petrol engine is concerned. But it is the layered surfaces within the body and the flowing shapes that form the integral rear wing that set it apart. Its design goes further than pure visual appeal, though. It represents the advanced technology that has gone into both this new BMW and the more affordable all-electric i3.
The Porsche is 199mm shorter, 132mm narrower and 7mm taller than the BMW, but still has a pleasing appearance almost two years after this latest incarnation arrived.
The i8 features a lightweight carbonfibre-reinforced plastic body and is underpinned by a chassis made almost exclusively from aluminium. But unlike the boxy i3, the new i8 has a plug-in hybrid drivetrain consisting of both a conventional petrol engine and a pair of electric motors.
BMW says the i8 weighs 1485kg, which is impressive given that there’s 200kg of lithium ion batteries running down the centre of the cabin. The aluminium-bodied Porsche tips the scales at 1430kg in PDK form.
Getting into the i8 isn’t easy. It requires a good deal of gymnastic dexterity to fold yourself between the lower edge of the scissor door and the substantial slab of carbonfibre sill. The 911, on the other hand, is a cinch to enter. Its conventional doors, relatively narrow sill and generous door openings are part of its enduring everyday appeal.
Swing your legs down into the i8’s footwell and you’ll find an interior that’s every bit as new world as the exterior, with deeply dished seats, a futuristic dashboard and a heavily sculptured fascia. And the Porsche? Its cabin lacks the sheer modernity of the i8, but there is nevertheless a satisfying completeness to it despite myriad buttons and switches.
When it comes to packaging, there is little to separate the two. Each provides seating for up to four, although the rear seats in both are really for emergency use only. As for luggage capacity, the i8 comes out ahead. The 154 litres under its glass liftback-style tailgate is 19 litres more than offered by the 911.
All up, the i8 boasts a combined 357bhp at 5800rpm and 420lb ft at 3700rpm. Just how much of this is available at any given time is dependent on the state of charge of the batteries and the drive mode that is chosen: Eco Pro, Comfort or Sport. Alternatively, you can select E-mode although it is only available when the batteries have enough charge.
Eco Pro and Comfort are entirely suitable for urban driving or cruising at a steady clip. Provided that the batteries are sufficiently charged, the electric motor within the front axle is automatically engaged. With 128bhp at 4800rpm and 184lb ft the moment that your foot brushes the throttle, it provides the i8 with zero-emissions front-drive running for limited distances up to an 80mph top speed.
The turbocharged 1.5-litre, three-cylinder petrol engine mounted at the rear engages when you give the throttle a decent nudge or when the energy in the batteries is depleted to a preset level. The engine is a more highly tuned version of the unit first unveiled in the new Mini Cooper.
It boasts the highest specific output of any current BMW engine, with 228bhp at 5800rpm and 236lb ft at 3700rpm – all channelled through a six-speed automatic gearbox to the rear wheels, essentially giving the i8 part-time four-wheel drive.
A second electric motor, mounted at the rear, acts as a generator to integrate the operation of the combustion engine with the front electric motor. There’s a brief interruption as the three-cylinder unit springs to life and begins to send power to the rear wheels, but it does not impede progress in any great way.
With the petrol engine and two electric motors working together in either Eco Pro or Comfort mode, the i8 feels powerful, but not explosively so. Peg the throttle at a standstill and the driveline delivers the sort of performance that you’d expect of a turbocharged six-cylinder engine, albeit allied to an odd, synthesised three-cylinder thrum.
The Porsche’s driveline lacks the complexity of the BMW’s, but it is not shamed for power. The 911’s naturally aspirated 3.8-litre flat six engine, mounted behind the rear axle, nominally delivers 395bhp at 7400rpm. Our test car is a US-spec model, though, and receives a power kit as standard, upping it to 424bhp.
It can’t match the BMW’s torque, though. With 325lb ft at 5600rpm, it gives away a considerable 95lb ft. In standard guise, it’s all sent through a seven-speed manual gearbox to the rear wheels, but our test car has the optional seven-speed PDK dual-clutch auto with better standing start qualities and superb shift quality.
The initial impression is that the i8 offers a very different driving experience from any traditional BMW sports car. There is an uncharacteristic lightness to the controls and a faint whine from the electric motor under load but, for the most part, the impression is of outstanding mechanical refinement.
The electric motor drives through a two-speed automatic gearbox, providing instantaneous responses and the sort of standing start acceleration to allow the i8 to challenge a well sorted hot hatchback away from the traffic lights in electric mode.
Drive it in isolation over a flowing back road without too many tightening second-gear corners and you may never doubt the dynamic ability of the i8. The steering is precise, if a little light, while turn-in is urgent and it happily accepts increasing lateral forces without awkward body movements.
With its electric motor and combustion engine channelling their combined reserves to all four wheels, there is plenty of traction and the brakes are powerful, albeit lacking in ultimate pedal feel. And besides some annoying patter at the front over pockmarked surfaces, the ride is quite compliant for a car of such sporting pretensions.
And boy, does it go when you put your foot down on the exit of a bend. On smooth roads, it is capable of keeping the rear-engined 911 honest, which speaks volumes for the effectiveness of its high-tech driveline. The Porsche has nothing like the same amount of low to mid-range torque; nor does it possess anywhere near the initial accelerative force out of corners.
But the 911 is not gutless. Above 4000rpm, its naturally aspirated engine provides prodigious shove. But by then, the i8 has already benefited from its initial spurt of electric propulsion and is away down the road. BMW claims 0-62mph in 4.4sec, compared with 4.5sec for the Porsche. However, a constant, linear surge of energy right from the outset makes the i8 feel considerably faster.
Read Autocar's full road test review of the Porsche 911.
The i8 would appear to tick the boxes that buyers of modern-day sports cars are likely to demand, but not if engagement and driving entertainment are your priorities. Seek out the final degree of dynamic finesse and you’ll discover one central weakness: a lack of front-end grip.
The new i8 rolls on 20-inch wheels, albeit only 7.0 inches wide at the front and 7.5 inches at the rear. They are shod with 195/50 tyres up front and 215/45s at the back and, with their limited contact patches, they lack for sheer purchase. The result? Early breakaway as you enter second-gear corners, followed by incessant understeer on a loaded throttle. As a result, the blinking yellow stability control system light is a constant companion on winding roads.
By contrast, the fluidity of the 911 is almost enough to seal this contest in one. It is so pure and involving that it makes the i8 feel stifled and artificial. The Porsche displays a lovely balance that prompts you to keep pushing at the sort of cornering speeds that begin to trouble the BMW, and there is a compelling completeness to the whole car, even as you approach the limits.
The Porsche’s steering is one of the best electro-mechanical systems fitted to any current production sports car. It is deliciously involving and perfectly weighted, and far more engaging than the light and over-servoed rack of the BMW.
And then there’s the rest of the 911’s absorbing dynamic character: its superb body control at any speed, the outright grip it generates, the terrific poise when loaded through a quick corner, the traction on the way out, the well-controlled ride and the way that its electronic driver aids allow you to dabble in a spot of tail-out action. Even if you put the i8 on its optional wider and stickier tyres, I still doubt that it could match the 911.
So the Porsche takes the dynamic contest – and by quite a margin. The tacit handling of the Carrera S is intoxicating on the right road.
However, the BMW is not disgraced. The i8 is one of the most intriguing sports cars to challenge the establishment in a very long time, and it is a clear winner in an urban environment, where its ability to run in electric mode and strong low-end torque make it wonderfully refined and amazingly frugal.
In the end, you can make a strong case for owning either one of these cars. If you’re an enthusiast and treasure driving, choose the 911. The Porsche is clearly more entertaining on a back road and the better sports car.
But if you’re keen on the futuristic appearance and are more obsessed with technology than dynamic appeal, go with the i8. The BMW’s blend of coolness and complexity makes it a compelling statement. Think of it as the world’s most accomplished urban sports car.
BMW i8
Price £94,845 (including government grant); 0-62mph 4.4sec; Top speed 155mph; Economy 135mpg (combined); CO2 49g/km; Kerb weight 1485kg; Engine 3 cyls in line, 1499cc, turbo, plus electric motor; Power 357bhp at 5800rpm; Torque 420lb ft at 3700rpm; Gearbox 6-spd auto (petrol), 2-spd auto (electric)
Porsche 911 50th Anniversary Edition PDK
Price £103,251; 0-62mph 4.2sec; Top speed 187mph; Economy 32.5mpg (combined); CO2 205g/km; Kerb weight 1430kg; Engine 6 cyls horizontally opposed, 3800cc, twin-turbo, petrol; Power 424bhp at 7500rpm; Torque 325lb ft at 5750rpm; Gearbox 7-spd dual clutch automatic
Peibolote
5 Dic 2010
A ver, que empiece la apisonadora...Cuantos os quedais con el i8?jajaja.
inthenight
19 Feb 2005
Yo no dudo de que el i8 sea un coche fuera de lo normal, en el sentido más amplio de la expresión, pero a mí ponme un 911 de estos raros, sí hombre de estos atmosféricos con sus 400cv que van a quedar obsoletos...
paramo M power
rural
2 Ene 2008
Con mi economía si me dan a elegir como regalo elijo el bmw , por que con el y pocos euros me paseo por media España disfrutando de un deportivo con el porsche la economía solo me daría para rodar por la comarca
Peibolote
5 Dic 2010
Si te da la economía para gastarte los 130000 del i8, para gasolina del 911 también. Los 911 de ahora tragan si se les da cera, a ritmo normal muy muy lejos del v10 del e60 por ejmplo :guiño:Es más, el consumo es de lo mejor en estos porsche de ahora.
j*der, ni en sueños pensé que estaría tan cerca del último 911 con 400 jacos, en uso deportivo.
Yo si, elegiría i8, sin dudar.
Le mans
5 Dic 2013
He tenido la suerte de ver y tocar el i8 (no conducir) y la verdad es que impresiona, tiene "algo".
Nacho Martinez
21 Abr 2002
Yo de debido leer otro articulo...o quizás estés buscando en el i8 algo que no es lo que muchos buscamos en coche deportivo. :fiesta2:
Todos los puntos en los que el i8 destaca frente al 911...son los que menos me harían comprar un coche de este estilo...la verdad.
Si es para pasear, no achucharle porque no tiene grip, ir en modo ECO por el centro de L.A, o ir de hipster geek tecnológico...entonces si. El i8 es mejor...:whistle:
En el uso que normalmente se le suele dar a un coche con claros tintes deportivos...yo en el artículo leo otra cosa bien diferente a estar siquiera cerca al 911.
Pero ambos estamos como dicen los anglosajones "biased"....tu tienes un coche que te da lo que no ofrece el i8....y yo tengo un cangrejo.
:p
Nacho Martinez
21 Abr 2002
Algo tiene....o mucho, diría yo. todo depende del enfoque o lo que se espere de el. EL que lo compre como deportivo...creo que se llagará un buen chasco!
Lucas M
13 May 2003
Para mí un i8 a diario y un 911 clásico para los findes
Hay algún aspecto del i8 que no acaba de agradarme y que considero es necesaria una prueba de conducción, como el incesante trabajo del cocntrol de tracción en carreteras sinuosas. Espero no sea demasiado intrusivo...
Le mans
5 Dic 2013
Segun todas las pruebas si es deportivo... pero no al nivel de un 911 o F Type, claro, sin embargo, tiene otros "encantos".
Yo de entrada ya veo sus dimensiones (para mi es muy grande) y lo veo menos enfocado a ese uso, por ejemplo: en cambio bastante más GT-autobahnero y commuting/ urbano, donde marcará mucha diferencia.
Dicho lo cual, a ver quien esperaba semejante resultado con un 3 cilindros gasolina y un eléctrico, a mi me sigue pareciendo increíble: no es ni un M y ahí lo teneís en comparativa con el último 911, nada menos.
(Comparativa en que si se aplicaran los criterios usuales, debería ganar: pues tiene más maletero :LOL:)
dani2
30 May 2002
Yo es que lo siento, pero a ese nivel....911. Y si, el i8 tiene cosas que lo hacen atractivo...pero como deportivo de capricho, yo sigo teniendo un buen motor térmico como un MUST....Para otro tipo de vehículo, la planta motriz del i8 me vale....para un deportivo no.
De la misma forma que para un roadster no cogería un 4L delantera.....o para una berlina de representación un 4L diésel....
Cuando no quede otro remedio por normativa o por falta de opciones. Vale. Pero mientras haya marcas que se dediquen a sacar cositas como este 991....pues no oiga.
Nanitopicolini
e46 320D
24 Ago 2013
Yo soy de bmw pero el 911 es mucho 911... casi que preferiría el porche.
Nacho Martinez
21 Abr 2002
entonces para que un esbelto cuerpo de superdeportivo...si lo que ofreces es un GT-???
EN cuanto a que "ahi teneos la comparativa...vs el 911"...joer, repito, no veo tal comparativa. Ciertamente en forma, es un deportivo...pero en su funcion...falla como tal.
Veria mejor compattiva vs en Lexus Coupe nuevo ese (no recuerdo el nombre), o Infinity Coupe...la verdad, o vs un Mercedes Clase Coupe...vehículos mas orientado a un a conducción relajada, que pueden aspirar en momentos determinados a ofrecer cierto disfrute...
Compararlo con el 911...creo que apra BMW es un error, y ponerlo en el mismo plano también, amen de penalizar al M4...que es la verdadera competencia del 911 en la firma, y que ofrece cosas que no puede ofrecer el 911, con un comportamiento similar.
No, si comparar es lo que tiene: vale todo. Lo que hay que ver es si lo que pueda perder en conducción estrictamente deportiva no lo gana justamente en otras facetas que para muchos usuarios tienen más peso (porque, de entrada, jamás meten sus coches en circuito ni salen de curvas)
No nos engañemos, si se han vendido hasta 911 tiptronic: ya solo ello quiere decir que hay un amplio potencial de clientela a quien la deportividad "real" del 911 se la refanfinflaba, de entrada (pasa hasta con los modelos más insospechados, no es cosa del 911)
Peibolote
5 Dic 2010
Y a que no tire de atrás el i8 no le ponéis pega??jejjej Ah! es cierto, es bmw y es un concepto diferente de automóvil.
antuan
19 Jul 2007
La historia de siempre, quien compra esto nuevo (generalizando con un poco de mala leche) es para pasear por el bulevar de turno, y ahí un 911 es el icono perpetuo que ya cansa quizá no para los que soñamos con el algún día pero sí para el que ya está ahí y no quiere el del montón,,, por eso el i8 entre que es nuevo, toda la carga tecnológica y luego este marketin tan convincente para "especialitos", vamos es que no me extraña que esté arrasando, bueno sorprendente sí es porque triunfa donde otros muchos fracasaron, bueno ni fracasaron, es que ni llegaron a cuajar trooooooon
MiniFER
Vicepresidente Ejecutivo
El 911 es mi coche preferido, de toda la vida. El factor decisivo es que mientras no tenga otro remedio usaré motores de los de siempre. 2 a 0 para el Porsche, y no saco del banquillo el precio ni el diseño.
Con lo que vale el i8, por favor, un M4 cabrio alicatado hasta arriba y más allá.
FJ.Gomez
30 Ene 2007
Yo si mañana comprara un 911 seria con pdk, no manual y no tiene nada que ver con la "comodidad de un automatico" si es a eso a lo que te refieres, ahí tienes como ejemplo todos los ferraris con cambio automatico, no sacan ninguno manual y el nuevo porsche gt3 solo se ofrece con cambio pdk.
Yo tengo clarisimo que compraria antes un 911 antes que el i8
Uy si ya empezamos confundiendo tiptronic (escribí step por error) con pdk y Ferraris "automáticos"....a eso mismo me refería. :guiño:
FJ.Gomez
30 Ene 2007
No, no me he confundido, en la actualidad son cambios pdk y por ejemplo un 996 turbo con trip no creo que precisamente sea un coche para pasear....
Pues yo discrepo, semejante transmisión ya por si sola lo sitúa muy alejado de la filosofía esperada de un deportivo, al menos para mi: no es el caso del pdk, otro mundo.
FJ.Gomez
30 Ene 2007
Pues todavia hay gente defensora de un cambio manual frente a un pdk, supongo que eso va con los gustos o manias de cada uno.....
ca_bmw
18 Mar 2004
:p
no se puede explicar mejor:
ahora mismo el 911, cualquier motor que suene y cuanta menos electrónica mejor
para dentro de 10, 20 años que estaremos todos aquí (más) aburguesados, el otro
a los motores de combustión les queda recorrido, pero cada vez menos, van hacia abajo capados por burocracia de emisiones, irán a menos en los aspectos más apasionantes mientras que los otros irán a más y mejorarán en prestaciones (la de velocidad máxima sigue siendo abismal)
por mi parte aguantaré todo lo que pueda con motores que hagan ruido, incluso aunque sea a tractor biggrin tiempo habrá en unos años y de sobra para pasar al lado "verde", que por otro lado serán muchísimo mejores cada vez
Lucas M
13 May 2003
Hay que valorar el coche como lo queces, un concepto nuevo. No tiene nada equivalente, es tan loable compararlo a un 991 que a un Auris hibrid
Si lo que queremos un superfeportivo híbrido tenemos el 918 o el P1 de Maclaren, que están a años luz en prestaciones y precio
Mentalmente creo que debemos abrirnos a éstos cambios y fijaos que como enamorado del 911 he dicho que junto al i8 tendría un 911 clásico.
Ojo, eso....y que hay gente que seguramente no tendrá que elegir, no lo veamos con nuestros ojitos de aficionados siempre limitados: lo más seguro que sea el caso de los 30 compradores de los i8 para España en 2014... pero ya ni digamos los de Paris o Londres o San Francisco...
De hecho me inclino a pensar que todos ellos tendrán muy superada la "necesidad" de un 911 :guiño:
No tendría ninguna duda a la hora de elegir. 991 sin ningún género de dudas.
Lo único que me aporta el BMW es un menor consumo, pero en todo lo demás barre el Porsche. Estética, efectividad, motor, sonido, sensaciones al volante... Por lo tanto, el BMW no me aportaría NADA que yo valorase.
