Fotos BMW M2 G87 (2023) OFICIAL
Precios en USA de accesorios M Performance
attachment.php
2023 BMW M2 G87 Vehicle Owner's Manual Notes / Highlights
2023 BMW M2 Owner's Manual
2023 BMW M2 Owner's Manual: Navigation, Entertainment and Communication
Manual
- drift analyzer warranty note - use at own discretion
- Rear seats fold 40/20/40
- Break-in periods:
- 200mi for tires
- 300 for brakes and clutch
- 600mi 5k RPM max
- 1200mi 6k rpm max
- Roof rack is fully functional as on regular 2
- M sport mode and Race track use can affect warranty - brake lining (pads) not designed for track use
- Drive away without delay - do not warm engine while parked
- Tire pressure <100mph 32/33, >100mph 35/38 stock wheels
- Typical jack points, lug bolts are 101lbft
- Recommend shell v power gas of 91octane
- Ethanol max is E10
- Recommend bmw fuel additive to remove deposits every 3k miles or 1k mi under high wear (short trips <5mi)
- Oil 0w30 - BMW Oil
- Turning radius 39ft
- Payload 772lbs
- Max weight gross 4751lbs
- Fuel tank 13.7gal
2023 BMW M2 performance parts Pricing
19 feb 2023
diavliyo
M3
3 May 2014
De momento no hay ninguna prueba con vídeo en español no ?
Gracias
Unos cuantos cacharros, atención al M2 negro a 27º bajo cero :pompous:
2024 BMW X2 M35i, iX1, M235i, M2, M3, M5 Competition Winter Testing in Norway
22 feb 2023
BMW winter testing in Kautokeino, Norway in -27C
Slasher
Baneado
21 Feb 2023
De lo más potable que tiene BMW actualmente, aunque me sigo quedando con el anterior 2.
diavliyo
M3
3 May 2014
Alguno lo tiene pedido....
IND | Motorsport+ G87 M2 CSL Style Yellow DRL LED Module Set
*AVAILABLE EXCLUSIVELY FROM MOTORSPORT+ AND IND*
One of the special details of the new BMW M4 CSL are the motorsport yellow daytime running lights. Evoking the look of GT racing cars, the BMW Laserlight headlights with yellow running lights bring a touch of the racetrack to the front of the new BMW M4 CSL. Both in the welcome sequence triggered when unlocking the doors and when the low and high beam headlights are switched on, the angular daytime running lights illuminate in yellow rather than white.
Now you can bring the same motorsport detail to the front of your G87 M2 with new LED boards for your Daytime Running Light modules.
NOTE: LED modules include amber corner LED for North American models; the amber corner LED will not operate in international-spec cars. No error codes; proper functioning for all models.
Product Details:
  • Applications:
    • All G87 M2 with Adaptive LED (11-pin DRL connector)
    • G42 2-Series with corresponding Adaptive LED headlight option (ZDD / 552)
  • Plug and Play installation; no ugly wiring, no error codes
  • The OE LED boards utilize two Torx screws and a very small thermal adhesive pad to fasten to the heatsink. The new CSL boards include a full size, pre-applied special thermal adhesive to aide in heat transfer and help longevity; remove original LED boards and just peel and stick the new CSL Yellow LED boards before replacing the screws
  • Set includes LED boards for both driver and passenger side headlights
  • Installation instructions included
The Motorsport+ G87 M2 CSL Style Yellow DRL LED Module Set may be viewed at the following link to our online store:
https://ind-distribution.com/product...led-module-set
Please contact IND by phone or email for more information or to place your order.
866.963.4520 | info@ind-distribution.com
__________________
jagus
3xBmw
6 Abr 2005
Cada vez me va gustando más....
Boletín de información de servicio: RUIDO DE CRUJIDOS/CRUJIDOS DEL EJE DELANTERO/SISTEMA DE DIRECCIÓN
Parece que el M2 está equipado con el EPS que tiene este problema. No se menciona qué fechas de producción se ven afectadas. Lo más probable es que incluyan esa información en la actualización de abril de este SIB.
MODELOS AFECTADOS
F95* (Vehículo deportivo X5 M)
F96* (Coupé deportivo X6 M)
G05* (Vehículo deportivo X5)
G06* (Coupé deportivo X6)
G07* (Vehículo deportivo X7)
G20** (Serie 3) Sedán)
G22** (Serie 4 Coupé)
G23** (Serie 4 Convertible)
G26** (Serie 4 Gran Coupé)
G29* (Z4 Roadster)
G42** (Serie 2 Coupé)
G80* (Sedán M3)
G82* ( M4 cupé)
G83* (M4 convertible)
G87* (M2 cupé)
Solo vehículos equipados con dirección asistida eléctrica (EPS) de ThyssenKrupp Presta Steering (TKPS) como se indica a continuación.
* Los vehículos están equipados con un EPS de TKPS
* * Los vehículos pueden estar equipados con un TKPS o JTEK EPS (solo G20, G22, G23, G26 y G42), estos vehículos deben verificarse primero para ver qué EPS está instalado.
CORRECCIÓN
Reemplace uno o ambos conjuntos de tirantes.
attachment.php
attachment.php
attachment.php
Toronto Red, Zandvoort Blue y Brooklyn Grey
BMW-M2-G87-Farben-Vergleich-Zandvoort-Blue-Toronto-Red-Brooklyn-Grey-Live-sidebyside-02-1024x684.jpg
BMW-M2-G87-Farben-Vergleich-Zandvoort-Blue-Toronto-Red-Live-sidebyside-02-1024x683.jpg
BMW-M2-G87-Farben-Vergleich-Zandvoort-Blue-Toronto-Red-Brooklyn-Grey-Live-sidebyside-01-1024x682.jpg
BMW-M2-G87-Farben-Vergleich-Zandvoort-Blue-Toronto-Red-Live-sidebyside-01-1024x682.jpg
Que gordura :chulo:
BMW-M2-G87-Farben-Vergleich-Zandvoort-Blue-Toronto-Red-Live-sidebyside-03-1024x682.jpg
BMW-M2-G87-Farben-Vergleich-Zandvoort-Blue-Toronto-Red-Live-sidebyside-04-1024x682.jpg
BMW-M2-G87-Farben-Vergleich-Zandvoort-Blue-Toronto-Red-Live-sidebyside-05-1024x684.jpg
diavliyo
M3
3 May 2014
BG sin duda...
Dicen que las primeras pruebas a partir del 18 de este mes...
revistacar lo a probado....
The Manual Power of the 2023 BMW M2 ft. Milo Ventimiglia | BMW USA
BMW USA
13 mar 2023
Join Milo Ventimiglia as he showcases exactly what the BMW M2 is all about: power, performance, and unparalleled style. The 2023 BMW M2 is a symphony of high-performance, aesthetics, and attitude with M-specific enhancements that bring you next-level control. You expect intense performance from BMW M – and the M2 Coupe meets that request beyond measure. The 3-0 liter BMW M TwinPower Turbo inline engine roars to life with 453 horsepower & manual transmission. Unparalleled design inside and out pushes this M2 Coupe into legendary territory – now it just needs you to take command.
