M3 E30 Aero...hay gente para todo. Un crack
cifu
Laetitia Casta
3 Ene 2004
Como me gustaría tener tiempo y dinero para hacer estas cosas a un coche...y por supuesto conocimientos. Leerlo entero porque el tío lo explica muy bien.
Hi guys,
It's been a while since i last mentioned anything about this car, but i hope you'll find the wait worthwile
For the time being, i'm just copying the text for the Photostory of the car at www.e30.de - car is featured there on 13.3 2009. Hope you have some questions ready
The car was started as a salvage project for a nearly destroyed engineless M3 chassis I bought, that had no engine at the time. The idea was to use a SAAB engine, which is a very reliable choice and able to cope with bad fuel quality we have in Serbia, and to build a car that will be used on occasion, for track, etc.. In the meantime I decided to built an all-round car with no corner left untouched, so this project was started, and took 2 years to finish. The result is the car shown here.
Car was built by members of 011 Racing Team in Belgrade, Serbia, with lots of ideas, help, input and advices from Presho, guys at Maptun, Cannonball Forum, and lots of other people too numerous to mention that were invloved in the Project. Thanks to all!
Regards
Aleksandar a.k.a. 206
Engine:
- Concept by Presho a.k.a. BOOST @ www.cbc.rs, built by 011 Racing Team: SAAB B234 2.3l, Trionic T5
engine [COLOR=blue ! important][COLOR=blue ! important]management[/color][/color] featuring automatic ion knock and boost control, individual Stage X tune by Fredrik @
Maptun Performance – www.maptun.com
- Garrett GT35xxR hybrid @ 1.9bar
- RC Engineering 1000cc injectors, Intercooler with CO2 spray, fuel CO2 cooler, Mocal water/oil heat
exchanger, TIAL 44mm wastegate, Turbosmart 38mm Blow-off valve, Turbosmart adjustable fuel pressure
regulator, 2xBosch Motorsport fuel pumps, ATL Fuel Cell, Wizard of Nos direct port nitrous system with
progressive controller
- Power measured by Rototest: Wheel power - 472PS / 573Nm; Engine power ~550PS / 670Nm on 93
octane fuel. Power with 102 octane fuel: 650PS / 750Nm
Chassis/body:
- E30 M3 Evo chassis
- Sparco full weld-in roll cage
- Front strut brace
- Rear floorpan, diff mounts and subframe additionally cross-braced and strengthened
- Candy Red paint
Transmission:
- E36 M3 6-speed gearbox coupled to SAAB engine block
- SPEC full cerametallic clutch plate
- Carbonfibre propshaft by ACPT
- E28 M535 rear diff 3.07 ratio
- Quaife ATB limited slip
- PPF driveshafts
Brakes:
- Front: Compbrake 6-pot calipers, 340mm Powervane floating 2-piece rotors
- Rear: Compbrake 4-pot calipers, 315mm rotors from E36 M3 3.2
- Tilton hydraulic pedal box 6.2:1, non-servo
- Tilton Hydraulic handbrake
- Tilton brake bias adjuster
- Electrohydraulic linelock
Suspension:
- H&R Coilovers height adjustable
- KMAC adjustable camber/caster plates front
- KMAC adjustable camber/toe ki
- Aluminium rear shock mounts
- Aluminium control arms
- Polyrethane bushings front & rear
Interior
- Sparco Pro 2000 seats
- Sparco 6 point harness
- Custom made alcantara upholstery + Dynamat sound and thermal insulation
Electronics & electrics
- OMP electric fire extinguisher boot/cockpit/engine
- Power kill switch
- Defi Link BF computer controlled gauges: boost, EGT, fuel pressure, oil pressure, oil temperature
- Innovate A/F gauge
- Innovate datalogger
- Intercooler cold / hot charge temperature
- Wizard of Nos nitrous controller with nitrous-based turbo antilag system
- Custom made central panel – fan, nitrous, linelock, N2O, CO2, antilag
- Custom made dashboard
- Electronic cooling fan control
- 5000k HID headlights
- Engine oil pressurizing system for cold starts
- Oil & water recirculation system after engine shutdown to prevent turbo damage
Tires & wheels
- BMW forged 18”
- Front: 8J/18 + 15mm spacers, Toyo R888 225/40/18
- Rear: 9.5J/18 + 10mm spacers. Toyo R888 255/35/18 or Mickey Thompson ET Street Radial 245/40/18 or
Mickey Thompson ET Street drag 26x10.5-15
Performance:
- 0-100: ~4.5s
- 100-200: 7s
- Max speed: over 320 km/h
I've got about 1000 pictures of the whole build, but for the moment just a few pics of the car we started with and the finished ride :
BEFORE:
AFTER:
I' open to questions, comments, critics, anything, so fire away
Also, got MANY more pictures, so if anybody's interested in anything in particular, ask. It would be WAY to much to post all the pics, as virtually EVERYTHING on the car has been modified in some way, but i'm sure you'll be interested in some stuff i did on the car.
regards
Aleksandar
jmompez
8 Dic 2006
Un maquinon, aunque es un poco macarra. Lo que no se cree ni el son las prestaciones que ha puesto, aparte que una preparación de BMW, mejor con motor BMW y no Saab
G
GaLLeGuiTo_Ti
pos va a ser ke yo lo de leer en otros idiomas pues....va ser ke no!!pero le ha kedado precioso!!!!
warrior69
15 Jun 2006
Se lo ha currado pero que muy bien
650?? Mi ingles no es muy bueno, pero creo que pone eso... impresionante.
cifu
Laetitia Casta
3 Ene 2004
jmompez;6940325 dijo:
Lo de macarra o no eso ya va sobre gustos, evidentemente no buscaba un producto original, pero tiene un trabajo y unos conocimientos de la leche.
Si te parecen dudosas las prestaciones, mirate bien la potencia que obtiene:
Yo lo veo factible totalmente.
sebas318i
16 Oct 2007
pues creo que quitando los pilotos traseros, me encanta ese coche, y ese color le queda muy bien, a mi gusto, pa gustos colores
jmompez
8 Dic 2006
cifu;6940414 dijo:
Si en la teoria si que es factible, ahora, pasar toda esa potencia proveniente de un turbo como una ensaimada de mallorca de grande al suelo, con un chasis de hace 25 años no creo que sea tarea facil.
Eso si, merito no le quito ninguno, ya que meter un motor de otra marca a un coche es complicarse la vida un huevo
9 Ene 2008
que quereis que os diga,no me gusta nada pero nada de nada,mira que ponerle un motor de un saab,por dios que sacrilegio.[-X
cifu
Laetitia Casta
3 Ene 2004
jmompez;6940462 dijo:
No creo que sea tan zoquete de ignorar ese exceso de par quedando el chasis de serie, de hecho lo refuerza.
Mira el corazón con su ensaimada
jmompez
8 Dic 2006
cifu;6940533 dijo:
No creo que sea tan zoquete de ignorar ese exceso de par quedando el chasis de serie, de echo lo refuerza.
La verdad es que impresionante es un rato
C
CaCereÑo
A mi el interior me encanta, el exterior y demas algo tunerillo para mi gusto.
cifu
Laetitia Casta
3 Ene 2004
CaCereÑo;6940556 dijo:
Yo desde luego le habria quedado los pilotos traseros originales y otras llantas, incluso las de origen o un modelo similar de BBS en 17"
Cris
///M3 ///M330 ci
22 Jul 2005
que preciosidad!!
victor316
E30 316, 320 ic
21 Sep 2003
Qué quereis que os diga?, como trabajo es muy fino, el coche ha quedado perfecto, pero hacerle eso a un M3 E30 es como montarle un motor TDI a un Deltona, por mucho turbo que sea.
Queréis un trabajo fino y respetuoso con la marca?. Pues mirad este, y no hace falta irse a foros extranjeros, porque este es de la casa
http://www.bmwfaq.com/f148/creacion-de-335i-e30-346440/
TML
20 Nov 2008
Y esa foto con los faros delanteros cuadrados?? :eek:
24 Feb 2008
que gordo........que maquina el tio, menos los pilotos traseros lo demas de 10!!!
pd: pedazo secador que lleva!!!
Izanhut
M50B20-GA16DE
26 Dic 2008
Que pasada de carro. Ya me podria dar una manita al mi E34...
4Aiur
335d E92
8 Mar 2005
Le ha quedao flipante... ahora que yo me planteo cuanto se gasta la gente a la hora de dejar un coche así y no se si le merece la pena.
McClane
Moderador Informática
2 E30, 1 E39
20 Jul 2006
El coche, ACOJONANTE, como buen amante del M3 E30 que soy. El motor, que se lo meta por el tracas. El M3 E30 ha de llevar su S14, o como mucho, un S54, y ya estamos hablando de una pequeña "aberración", así que meterle esa "castaña" de motor... :-k
odres
24 Nov 2006
Pues no esta nada mal...........
Sargento_Duke
2 Oct 2005
Las BBS le quedaban mil veces mejor, unas precioas styling5 en 17...
Las doble palo del Z8 las tenia yo en el e36 y son macarras.
jagus
3xBmw
6 Abr 2005
pues yo lo felicito, creo que ha hecho un coche a su gusto y que además, le ha quedado GENIAL!
cassanova
10 Dic 2007
victor316;6940668 dijo:
Está mucho más bonito ese blanquito!!!!
Barbinski
PHEV tester
Q5-Q5sb-S2R1000
18 Mar 2004
Impresionante trabajo pero..... esas llantas no me gustan, ese injerto de un SAAB :)bash:) es una herejía, no me imagino la currada para acoplarlo a una caja de //M3 E36..... Y luego esos más de 320 kmh.... no sé, no sé....el E30 no tenía la mejor aerodinámica del mundo precisamente...
Chicharro
12 Feb 2004
Mil veces mejor de origen con su blanco y sus llantas de 17"...........
Han jodido ese M3 lo siento!!!:bash:
Manolo71
M3E46,545E61
4 May 2008
Esta gente que es capaz de hacer cosas asi para mi son artistas.
No me gusta lo del motor saab por que creo que en BMW hay motores de sobras para elegir.
Eso no quita de que sea un trabajo excelente...lleno de detalles y muy a su gusto como por ejemplo las llantas,esas no le pegan mucho al E30.
En dos palabras...IM-PRESIONANTE...a mi me gusta mucho.
R
Rafa321
Un motor de 5 cilindros en linea, es una de las disposiciones ideales bastante superior al 6 en linea, el motor que lleva es cojonudo y facil de preparar yo no lo veo ningun sacrilegio, sino una opcion relativamente barata y muy acertada.
josevet-69
530D E60
21 Dic 2007
Pues como casi siempre siento ser el mismo de siempre, pero yo no me gasto ese dineral en ningún coche viejo por muy clasico y chulo que pueda quedar, me quedo con el M3 de ahora.
victor316
E30 316, 320 ic
21 Sep 2003
josevet-69;6942121 dijo:
Lo que tu digas
