Hola yo lo he conectado por bluetooh de dealextrem y un note 3
En principio solo he realizado un diagnosis de la cual me saco 32 fallos este sabado, y hoy al llegar del trabajo , realice una nueva diagnosis y me saco 9 fallos , a ver si alguno me echa un mano a saber que es ....
Os pego el txt que genera el programa :
Fault Report - BMWhat - Version: 14.03 FV
ID1: 83e57121-ed26-4bfb-9424-c8c231619406-855
ID2: b06636f8-e847-4900-83a0-81afa53baca2-c34-44c2
INFO: 0C01E4D3C2BEA1977E6D5C4B3A2A
Base: E60 E61
Faults: 9
ECUs: 28
Filter: just found
Model: 530 d M 57 3 06 D 3 (44)
Battery: 12.2V
Comunicacion normal
conexión normal
Normal Comm-Speed
B 1
Date: 2014-10-06 22:27:15
OBDII
Version: 19
Device: >samsung< >hltexx< >SM-N9005<
Motor Control:
Engine / Motor
Fehler: Fuel Filter
Code: 4587
Fehler: article filter system
Code: 480A
Fehler: unknown failure / Particle filter system / Exhaust back pressure sensor / partical filter system / Exhaust back pressure sensor against particulate filter
Code: 4D00
Fehler: Air charge control, anomaly / TCU pos / Charge pressure control error / Air-filling control / Air-filling control, deviation / Air-filled deviation
Code: 4530
Fehler: Cylinder 3 Glow Plug / Glow plug on cylinder 3 / Glow plug cylinder 3 / Glow plug cylinder 3, control
Code: 4232
ABS / DSC / Brake:
Dynamische Stabilitaets Kontrolle / DSC
ECU OK, no hay codigos de averia
Airbag:
Transmission Control:
Instrument cluster:
Instrument cluster / Kombiinstrument
Central info display / Zentrales Display
Fehler: Central control timeout
Code: A468
Head-Up Display
Light/Rain Control:
Rain/light sensor / Regen-Lichtsensor RLS
Light / Licht
Heating / AC:
Air conditioning / Klimaanlage
Fehler: Heating nozzle / unknown failure
Code: 9C78
Fehler: Short circuit to positive or open circuit - additional water pump / Refrigerant compressors
Code: 9C77
Immobilizer System:
CAS
Park distance control:
Park Distance Control / PDC
Cruise Control:
Sunroof / Roof:
Sunroof / Schiebedach
Audio/Navi/Communication:
Phone / Telefon
Tuner Antenna / Antenne
Audio-System
Seats:
Seats / Sitze
Seats / Sitze
Systems:
Gateway
Steering column switch / Lenkstockschalter
Fuel pump / Kraftstoffpumpe
Passive Go System
Fehler: Bumper-defective antennas / unknown fault
Code: A06B
Car Communication Computer CCC
MASK
Center-Konsole
Car Communication
Anti-theft alarm system:
Chassis:
Air suspension / Luftfederung
Central Control / Zentrale Bedieneinheit
Body:
Car Body Module
Tailgate / Hecktuer
