Base: E46
Faults: 20
ECUs: 7
Model: Automatic engine recognition
Battery: no hay información de la batería
Comunicacion normal
conexión normal
Normal Comm-Speed
C 1
Date: 2014-05-13 18:22:56
USB Device
Version: 19
Device: >motorola< >falcon_reteu< >XT1032<
Motor Control:
Engine / Motor
Fehler: Glow plug cylinder 1 / Glow plug on cylinder 1 / Glow plug cylinder 1, control / Cylinder 1 Glow Plug
Code: 4212
Fehler: Glow plug cylinder 2 / Cylinder 2 Glow Plug / Glow plug cylinder 2, control / Glow plug on cylinder 2
Code: 4222
Fehler: Glow plug cylinder 3 / Cylinder 3 Glow Plug / Glow plug on cylinder 3 / Glow plug cylinder 3, control
Code: 4232
Fehler: Cylinder 4 glow plug control / Glow plug cylinder 4, Control / Glow plug on cylinder 4
Code: 4242
Fehler: Boost Pressure control / Boost pressure plate B-CS / Air filling pressure regulator / Charge pressure regulation or charge pressure actuator / Boost Pressure switch / Boost controller / Boost pressure actuator control
Code: 4191
Fehler: Oil pressure lights / Oeldruckkontrolllampe / Oil pressure warning light / Oil pressure warning light, driving
Code: 42C2
Fehler: Internal control unit 20 / internal ECU 20
Code: 4491
Fehler: Rail pressure quantitative plausibility control / unknown failure / Rail pressure-plausibility quantitative control MaxPos / Plaus rail pressure. Crowd Control
Code: 4560
Fehler: Rail pressure quantitative plausibility control / Rail pressure-plausibility quantitative control Maxposfuelflow / unknown failure
Code: 4570
Fehler: Rail pressure monitoring / Raildruckueberwachung start
Code: 4B90
Fehler: Message fault / unknown failure / Data (INSTR3)
Code: 48E3
Fehler: Message fault / unknown failure / Data (INSTR2)
Code: 48D3
ABS / DSC / Brake:
Dynamische Stabilitaets Kontrolle / DSC
ECU no está presente / no hay respuesta de la ECU
ABS + DSC
Airbag:
Airbag
Fehler: STL error lamp / Airbag warning light (STL)
Code: 0051
Fehler: Seat occupancy detection
Code: 0070
Transmission Control:
Transmission / Getriebe GS20
Instrument cluster:
Instrument cluster / Kombiinstrument
Fehler: CAN Outside temperature / Outside temperature is too low - K-LIN 5.7 sunshade driver / passenger rear
Code: 00CE
Center-Console/ Schaltzentrum Mitte
Light/Rain Control:
Rain/light sensor / Regen-Lichtsensor RLS
Xenon right / rechts
Xenon left / links
Light / Licht
Light / Licht
Heating / AC:
Air Condition / Klimaanlage
Fehler: AUC heating / Engine ventilation valve
Code: 0020
Park distance control:
Park Distance Control / PDC
Cruise Control:
Cruise Control / Tempomat
Sunroof / Roof:
Sunroof / Schiebedach
Audio/Navi/Communication:
Radio
ECU OK, no hay codigos de averia
Navigation
Radio Navigation
Seats:
Seat memory / Sitz-Memory
Seat memory / Sitz-Memory Beifahrer
Systems:
Gateway /ZKE
Fehler: Wiper: pump for window cleaning or tank is empty
Code: 0038
Fehler: C-bus control unit or instrument cluster base (gateway)
Code: 0030
Fehler: Anti-theft alarm system: Siren, radio inside protection, tilt sensor alarm or wire STDWA short circuit to ground or open
Code: 0007
Kraftstoff Pumpe / Fuel Pump
Tire pressure control / Reifendruck
Body:
Elektronische Fahrzeug-Immobilisierung
Fehler: Power on Reset
Code: 000F
Passenger mirror / Beifahrerspiegel
Steering wheel / Lenkrad
Driver mirror / Fahrerspiegel
Roll-over protection / Ueberrollsensor
Other:
