Bueno , acabo recibir el cable + software, un DVD con 3 archivos comprimidos ( BMW INPA k+CAN(2012-1).zip, BMW inpa_2(old 2011).rar y inpa 2012 new.zip.
Estoy siguiendo la instalación del manual que adjunta pero me sale un error el punto 4.3 al darle al continuar que pone:
A LZH Archive not found. : `C:/IMPA.LZH´
Y ahi me he quedado.:roll:
El manual dice lo siguiente:
Installation INPA – EDIABAS FULL-English-Edition
1) Delete ALL versions of INPA-ADS from your computer or remane all INPA-ADS folders.
For example: remane INPA into “_INPA”, EDIABAS into “_EDIABAS” and so on.
2) Open folder Step_1\ in the root of CD-disk given. Copy folder EC-APPS onto disk С:\
3) Run file Step_1\NFS\Entpackt\disk1\SETUP.EXE
While installing choose User Mode
Further choose in opening windows:
1. Parametrieren einer neuen Konfiguration ohne Daten
2. OBD
3. Kein API-TRACE
4. Kein IFH-TRACE
5. Komfort (.IPO)
! RE-BOOT YOUR Computer !
4) Run file Step_2\INSTALL\Instprog.exe
1. Choose ENGLISH, press Continue, then press Continue again
2. While choosing the HDD disk for initial setup do not change letter C:\. Your
installation must be on drive С:\ ONLY !
3. Choose configuration BMW Group Rectification programs UK, press Continue.
4. Activate all spare boxes with : EDIABAS 6.4.3 - UPDATE, INPA 5.0.1 - UPDATE,
NCS Expert 3.0.8 - Complete
5. Press Continue.
5) Run file Step_3\INSTALL\Instprog.exe
4. Activate all spare boxes with: INPA 5.0.1 - UPDATE, NCS Expert 3.0.8 - UPDATE
5. Press Continue.
6) Find the file С:\EC-APPS\INPA\CFGDAT\ named inpa.ini and replace it with the file inpa.ini that is in the root directory of CD-disk given.
7) Plug the Adapter into spare USB-port and install drivers manually from the folder Driver_D_CAN_USB using Driver Wizard of your Windows XP-Service Pack-2
Que hago mal?
