- Modelo
- Z3 2.8 / GR86
- Registrado
- 11 Feb 2008
- Mensajes
- 108.602
- Reacciones
- 95.420
Manual de usuario del propietario de Godzilla (USA)
http://www.nagtroc.org/files/2012-Nissan-GTR.pdf
[yt]3YaV-zjswFI[/yt]
Aqui lo primero que vais a buscar,
el LAUNCH CONTROL (no usar mas de 4 veces seguidas para proteger transmision y embrague)
http://www.nagtroc.org/files/2012-Nissan-GTR.pdf[yt]3YaV-zjswFI[/yt]
el LAUNCH CONTROL (no usar mas de 4 veces seguidas para proteger transmision y embrague) El nuevo GT-R al detalle, presentado por un especialista del GT-R (UK)go to 5-31 thats launch control 4
R MODE START FUNCTION
This function enables the driver to start acceleration from a stop by selecting R mode with the
VDC and transmission setup switch. The engine
output will be maintained at approximately 4,000
rpm. When using the R mode or the R mode
start function, always use proper seating position and follow the safety instructions in Section
1 of this manual
HOW TO USE R MODE START
FUNCTION
position. M& or A& 1. Move the shift lever to the
2. Select the R mode with the transmission
“VDC, transmission and setup switch. (
suspension setup switches” page 5-24)
3. Select the R mode with the VDC setup
switch.
4. Depress the brake pedal firmly with your left
foot and keep depressing the brake pedal.
5. Depress the accelerator pedal quickly to the
floor with your right foot while the brake
pedal is depressed. The engine speed will
increase to approximately 4,000 rpm and
will be maintained.
6. Within 3 seconds after depressing the
accelerator pedal, release the brake pedal.
The R mode start function has been .
developed not only for controlling
the engine, transmission and VDC
system, but also the settings of the
suspension and tires. Therefore, any
modification of the vehicle may
disrupt the vehicle’s balance. This
will not only reduce the optimum
performance of the vehicle but may
also cause damage to powertrain
components, including the transmission.
If the R mode start function is used .
4 times consecutively, the function
may be disabled and cannot be
turned on to protect the vehicle
system. While the function is disabled, the warning light illuminates.
When the warning light illuminates,
perform cool down driving.
“Cool down” page GTR-12) (
When the warning light turns off,
the function can be used again.
The performance of start may vary .
depending on the amount of wheel
spin, or increase and decrease of
the engine output in response to the
outside temperature. (This vehicle
was set up according to the road
surface conditions of the straight
sections of the Sendai Highland
F8 Raceway course in Japan at 59
C).) 8 (15
VDC control automatically activate .
when driving on a slippery road
surface such when it is wet in order
to apply brakes or limit the engine
output for safety.
Frequent use of the R mode start .
function increases the load on the
powertrain related parts such as the
clutch and transmission compared
to normal driving. In particular, the
clutch will wear out more quickly
